Slide-In Electric Range with Flex Duo Turns On Bake When Door Opened
(Topic created: 05-01-2023 06:31 AM)
SandpaperSandy
Kitchen and Family Hub
Just installed this unit, and I notice that each time I open the oven door, the panel turns on displaying Bake function.
Does this automatically start a pre-heat or do I need to press start?
 Is there  way to turn this off?
Samsung_Moderator
Hi there, Thank you so much for reaching out about this. I can certainly understand the concern with the bake feature turning on when the door is opened. We would like to speak with you directly to get some more detailed information about this, and determine the best resolution. If you would, please reach out to one of the moderators here in a private message with the full model and serial numbers for your range, as well as any additional information about the symptoms you're experiencing.
Samsung_Moderator
Hi there, Thanks so much for reaching out to the community. In order to better assist you, could you please provide the full model number for your range?
jenn2mann
NE63T8751SS
jenn2mann
And the light in the oven is on,  How do I turn that off?
jenn2mann
Figured out the light.  Now to solve the problem of the oven turning on whenever I open the door.
jenn2mann
I just had mine installed and I'm trying to figure out why the oven turns on whenever I open the door.  When it first arrived, during the installation, it kept going to Broil. Turn off , open the door, broil.  Rinse and repeat,  I just finished the 1-hour 400-degree Bake cycle (removed the flex-duo divider) and now when I open the door, it turns on Bake mode at the default temp (325??).  Not a good start.
Samsung_Moderator
