- Mute
05-19-2024
03:14 PM
(Last edited
05-20-2024
09:32 AM
by
SamsungCaleb
) in
So yesterday I turned on my tv. And all the way to the left on the screen there's a thick grey vertica stripe and a white stripe. Has anyone had this happen to them. It's so random.
Solved! Go to Solution.
- Mute
08:47 AM
(Last edited
12-16-2024
05:37 PM
by
SamsungCaleb
) in
Hello, @userrwqjcSvnSg I agree with @GaryB82 on service being needed in this particular case. Here's is a link that you might find helpful: https://www.samsung.com/us/support/troubleshooting/TSG01202526/#lines-dots-or-spots-of-any-color-app...
If this does not help I recommend letting a service technician have a look. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
- Mute
05-19-2024 03:31 PM in
LED and OLED TVshttps://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
05-19-2024 04:32 PM in
LED and OLED TVs
- Mute
08:47 AM
(Last edited
12-16-2024
05:37 PM
by
SamsungCaleb
) in
