- Mute
â11-04-2024 09:27 AM in
LED and OLED TVsHi everyone,
Iâm experiencing a pretty frustrating issue with my Samsung 75QN90D, and I was hoping someone here might have a solution or advice.
The issue is that whenever subtitles appear on the screen, the TVâs Local Dimming feature reacts quite strongly. This causes a temporary over-brightening in certain areas of the image, especially on faces, which appear âblown outâ (probably due to an automatic adjustment in the backlighting). This only happens when subtitles are present, making the image look quite unstable.
Hereâs what Iâve tried so far:
⢠Lowering the Local Dimming to low: this reduces the effect, but the image becomes too dark, and I lose picture quality.
⢠Disabling Dynamic Contrast and switching to image modes like Film or Standard, but it doesnât fully resolve the issue.
⢠I also tried increasing the brightness to compensate when Local Dimming is set to low, but itâs still not an ideal solution.
Iâm getting a bit desperate because it feels wrong to have to limit the TVâs capabilities to avoid this issue.
Has anyone experienced this on this model or a similar one? Do you have any tips, specific settings, or ideas I might not have tried yet? Also, do you know if a software update could fix this problem, or am I stuck with it?
Thanks in advance for any help!
We can see the problem on the face with and without subtitle on the images exemple below
â
â
- Mute
â11-04-2024 09:34 AM in
LED and OLED TVs- Mark as New
- Mute
â11-05-2024 04:20 AM in
LED and OLED TVsMy TV is already up to date with the latest version (1120)
