- Mute
07-09-2018 10:34 AM (Last edited 07-09-2018 10:40 AM ) in
LED and OLED TVsI purchased my Samsung 4K HDTV, Model #: UN65JU6700FXZA, Version: TD01 about 3 years ago. I recently got a Xbox One X so that I could play true 4k games with HDR. However the HDR won't enable on my Xbox one X. I have been through all the troubleshooting I can find and forums and done what they all said helped them but it hasn't helped me. I went to the picutre settings and set port HDMI 1 to UHD Color (which samsung states is HDR). And I have checked to make sure my Xbox one is plugged in to that port. My HDMI cord is top of the line 2.0 18gps 4K gold plated all that good stuff. I have reset my TV and hard reset my Xbox one X. And I have tried muliple games which are confirmed HDR compatible and still the HDR mode is greyed out and unclickable on my Xbox one x. I am at a lost. Could a Samsung professional please help me I will be forever grateful, thanks!
Solved! Go to Solution.
- Mute
09-04-2018 09:34 PM in
LED and OLED TVsTv is as follows:
model code: UN49NU8000
sofware version: T-KTM2AKUC-1131.9,BT-S
Gaming console:
Microsoft, Xbox One X
model: 1787
Up to date on all software updates. Checked this afternoon.
Xbox HDMI cord connected to HDMI 2 on the TV.
Have tried plugging the TV and Xbox into seperate circuits in my home, didn't change anything. Both are now powered on the same outlet.
![](/skins/images/455D6337F76C25619EB72931B54B11FB/responsive_peak/images/icon_anonymous_message.png)
- Mute
09-05-2018 07:00 AM in
LED and OLED TVsHave you tried running it with the UDH Color setting disabled on the television?
- Mute
09-05-2018 07:57 PM in
LED and OLED TVsYes sir. I will try that again. I have not in a while
I tried all other HDMI ports and a different hdmi cable. The problem still persists. It seems to get worse the longer the xbox is running in 4k, ie the screen goes black more frequently for a longer duration each time.
![Samsung Moderator Samsung Moderator](/i/rank_icons/moderator.gif)
- Mute
09-05-2018 08:40 PM in
LED and OLED TVsHave you tried going to the Settings of the Xbox One and go to Display & Sound? There you should see the TV resolution set to 1080p. You would need to change it to 4K UHD.
- Mute
09-05-2018 09:46 PM in
LED and OLED TVsFor the love of everything sacred and precious, will one of the Samsung support team please, PLEASE acknowledge that the black screen issue is well known by everyone here and does not have a fix!
I am begging you!
No one here managed to get this issue sorted out, whether our TV is 4 years old or one of the latest.
Gaming is just one frustrating experience on Samsung TVs!
No cable, no setting, no voodoo priest will fix the problem.
- Mute
09-05-2018 11:04 PM in
LED and OLED TVsAs soon as I was done i flipped the HDR back on and within a cpl minutes my screen started going out. Of course I'd love to get both working, that's the original reason I bought the TV. But, unfortunately at this point, I'm just happy to get nearly an hour of 4k gaming in without a hitch.
I definitely feel your pain tho. And everyone else that has this issue. There really doesnt seen to be an answer. I had tried turning the UHD setting off on the TV manually before and it didn't work. For whatever reason, it did this time, for a short time. I'll try it again to see how it runs tomorrow when I have more time and report back.
- Mute
09-11-2018 03:23 PM in
LED and OLED TVsSo I've officially been able to play in 4K UHD on my 1 X, for as long as I want, no black screen. I still can NOT play in HDR though... What worked was manually turning off the HDR for the input through the external device manager in settings. I am using HDMI port 2.
Im running my 1 X on a 2018 49" NU8000. Nothing else special.
If anyone has a fix to run 4K with HDR, PLEASE LET ME KNOW! I've tried it all. In fact, i tried the workaround i mentioned above before and it didnt work a couple months ago. If anyone has any succes with anything please let me know! Hope this will help you guys at least be able to use 4K.
- Mute
10-28-2018 09:06 PM in
LED and OLED TVsI READ ON ANOTHER THREAD WHERE A GUY SAID TO GO INTO GENERAL SETTINGS NOT DISPLAY ON YOUR TV, THEN SELECT HDMI EXTERNALL CONNECTION AND MAKE THE FIX... A LOT OF PEOPLE HAVE SAID THIS WORKS...
- Mute
10-29-2018 01:32 AM in
LED and OLED TVsWould you mind elaborating a little more, please?
Do you have a link to that thread?
I would love to do some more digging and see what else you may have to say.
- Mute
11-12-2018 11:01 AM in
LED and OLED TVsI have it working fine. However it didn't at first.
You have to change the TV to "Game Mode". Then you can access the HDR options on the TV to turn it on. Then the Xbox One X will recognize it.
