Searching for Apps
(Topic created: 01-04-2025 01:27 PM)
useryuldcBg38J
Cosmic Ray
LED and OLED TVs
I must be missing something. I have been looking for the app search icon on my 50qn90qn. There are numerous apps available but I cannot locate the search icon. It used to be there. Any suggestions?
MrGhoul
Red Giant
LED and OLED TVs
I must say that it is really weird that you are experiencing that.I would submit feedback by going to the members' app homepage > tap support > submit feedback on the issue.
Also, reach out to samsung customer service 1-800-samsung
https://www.samsung.com/us/support/contact/
MrGhoul
Red Giant
LED and OLED TVs
That's strange. When you click on the apps icon, look for the magnifier glass icon (top right). You should also have a search icon (magnifier glass) when pressing the home button on the remote(scroll left).
useryuldcBg38J
Cosmic Ray
LED and OLED TVs
There is no magnifier glass on the top right of apps screen. If I use the one on the left side, it only searches for things regarding the tv. I'm wondering if I should update software again?
MrGhoul
Red Giant
LED and OLED TVs
Try and unplug the tv from the outlet for at least 5 minutes, then plug the tv back in. This has been successful in fixing issues. The tv should update software automatically, but by all means, check and see if your tv has the latest update.
useryuldcBg38J
Cosmic Ray
LED and OLED TVs
I followed your advice. Unplugged tv and still no magnifying glass. I also have the latest software update. Without the ability to search, I can not download apps. Any other suggestions?
MrGhoul
Red Giant
LED and OLED TVs
paulinho_bh
LED and OLED TVs
Same problem here!
