- Mute
01-28-2020 02:56 AM in
Other Mobile Devices
I was unable to turn on WiFi in my Samsung A10 so someone asked to me to do factory reset so I did...
I wiped all data and cleared cache.
Now I need to to connect to the WiFi to set up the phone but the wifi still can't be turned on.
I keep pressing on "turn on Wifi" button but nothing happens.
I can't even skip with window 😣
I can't afford loosing my phone.
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
- Mute
02-14-2020 12:39 AM in
Other Mobile DevicesOk, thank you for your help and suggestion.
- Mute
04-27-2020 03:29 PM (Last edited 04-27-2020 03:35 PM by SamsungRei ) in
Other Mobile DevicesI have a Galaxy A20. When, I say, "Login", OK.
But, it wants a password. I've tried a few.
It just, does not get me in. Now what?
If, you have the answer . . . .
Thanks for reading . . . Jerry . . . <edit>
- « Previous
- 1
- 2
- Next »
