Missing piece for wallmount on Samsung Frame TV
(Topic created: 01-25-2024 07:00 PM)
hsanchez83
QLED and The Frame TVs
Hi everyone,
I couple of weeks ago I bought a Samsung Frame TV QN32LS03CBFXZX at Costco.
Today when I was trying to install it I noticed a missing piece (Instructions has this number BN68-16012A-00 and the missing piece is called J). Is there any way I can get this piece?
Thanks
Samsung_Moderator
Hi there, Thanks so much for asking about this. You have a couple options here. First, you can check with our parts department about ordering replacement parts. You can reach them online at SamsungParts.com or by calling 1-800-627-4368. If it's been less than 30 days since you purchased the TV, you can PM one of the moderators a photo copy of your receipt to get a replacement sent out. Lastly, you may want to check with your retailer about exchange options.
1 Reply
Samsung_Moderator
