- Mute
06-06-2021 09:48 AM (Last edited 06-07-2021 07:13 AM by SamsungKim1 ) in
QLED and The Frame TVsHi all,
I purchased a 32 inch Samsung Frame (QN32LS03TBFXZA) and discovered that the mount brackets and screws appear to have been missing from the box. I am having a tough time figuring out how to get the missing parts sent to me so that I can mount my TV. Any ideas on how I can get these missing parts? I need the mounting plates that are into the wall, and the mount screws that go into the back of the TV that slide into the mount brackets.
Solved! Go to Solution.
- Mute
06-07-2021 07:15 AM in
QLED and The Frame TVsI would like to look at this a little more closely. Can I have you send your serial number via private message?
- Mute
