Galaxy S20 Ultra 5G will not work with Verizon 5G network
(Topic created: 12-10-2020 05:39 AM)
Not applicable
Galaxy S Phones
I purchased an unlocked Galaxy S20 Ultra 5g from Samsung with for Verizon but it will not work with Verizon's 5g network! Has anyone else experienced this or found a solution? Verizon told me to contact Samsung and Samsung told me to contact Verizon 🙄
userhoxH2dJzPM
Galaxy S Phones
Go to Settings>connections>mobile network>network mode. Switch to "LTE/CDMA". The phone will find the network, if you aren't connected to WiFi, you should see the 5G icon in the top right corner, once it finds the network.
Galaxy S Phones
2 things
one, you may not even have 5g in your area or on your phone.
two, go to Verizon and have them install a free, new SIM. Samsung may not have installed one, or they may have used one from a different carrier.
Not applicable
Galaxy S Phones
I will try that thanks, and I checked the coverage map and I do have 5g coverage
useronC2wdLe4a
Galaxy S Phones
Following.. I'm in the same boat- only receiving LTE+, no option to switch to 3G/4G/5G in the connection settings.
Not sure if everyone else is experiencing the same. Seems like everyones still waiting on the update from Samsung 🤷‍♂️
Galaxy S Phones
It is my understanding LTE + is the symbol for Verizon's version of 5G UW--at least on non updated UI 2.5 devices.
useronC2wdLe4a
Galaxy S Phones
Im actually really glad you mentioned that @Cheyennehoofhearted . I've been on wifi most the time and it seemed slow when I tested it before going to Verizon and switching my old SIM to the new 5G one. Does seem to be working fast again now, thanks😅
Hopefully I'm not imagining it. Hope everyone else's works too 👍
Not applicable
Galaxy S Phones
I went to Verizon last night and they put a 5g Sim card in my phone and as of right now I still only have LTE + 🤷‍♂️ anyone else? Will the update solve it?
FBOL
Galaxy
Galaxy S Phones
Just got Android 11 update on S20+ 5G and it includes VZW Nationwide 5G!
Not applicable
Galaxy S Phones
Me too!!!
userhoxH2dJzPM
Galaxy S Phones
