Problem with Galaxy s20 ultra wireless charging.
(Topic created: 03-09-2020 07:02 PM)
user0ebOig2Oyq
Galaxy S Phones
So I have a galaxy S20 ultra and having a problem with it charging wireless in my wireless car charger. At first I thought the charger might be defective or uncompatible with the phone. The charger works fine with my wife's S20+ but not the ultra. Also it works fine when I use both my wireless charger at home. The problem is it would charge then pause then charge then pause every 2 second. I tried turning fast wireless charging off and it still didn't change anything. Any help would be greatly appreciated.
JUMP TO SOLUTION
SKLZWL
Sun
Galaxy S Phones
I did that 2 weeks ago.😔
usert8NLcck6eo
Cosmic Ray
Galaxy S Phones
Stay tuned, either they stuffed the update or they did it on purpose to weed out generic chargers.
SKLZWL
Sun
Galaxy S Phones
but I bought my charger from Samsung. the UV sanitizer / wireless charger
SCA
Galaxy S Phones
I just spoke to a Samsung support associate and he said he filed a report for the developer to report. I cannot receive any direct comments from developer though. Hope they accept and fix it soon. Mine is S20 and started having problem since October security patch.
userkLnFgHxopS
Galaxy S Phones
Got the wireless charging issue after the October update.. anyone have a fix for it yet.. fast charges, pauses, charges slow speed pauses etc..
nabillion
Galaxy S Phones
I'm having the same issue with my s20 FE, while my note 8 charges fine.
usercklPaTm3ct
Galaxy S Phones
Same here with my S20+. Mine was starting and stopping every few seconds, I moved the phone on the pad and it was okay temporarily. Started again and so I restarted the phone which again solved it but no tfor long.
Updated this morning and now it's stopped altogether. Samsung, you need to get on this ASAP because this is clearly something you've caused.
usermvQfKUx4VO
Galaxy S Phones
Same issue here, charging keep on cutting off every 3 seconds with the S20 Ultra. Charger works well 100% with iPhone.
SamsungRyder
Galaxy S Phones
Have you been able to try any of the previously mentioned troubleshooting steps in the thread?
