Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
LeoWyatt89
Nebula
Galaxy S24
Hello, Welcome to the Community. We understand the concern of the battery draining quickly.
Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Note: The battery adaptive feature may cause the battery to drain a little faster at first until the phone adapts to your usage, and learns how you're operating, the charge will be stored and used in different manners based on how you use your phone. This sometimes can take a few weeks for it to learn the habits and customize itself to make sure you have the best performance and lasting battery.
https://www.samsung.com/us/support/galaxy-battery/optimization/
You can also try the steps here: http://www.samsung.com/us/support/troubleshooting/TSG01001388/
If you continue to experience the battery drain, we recommend having the phone evaluated by an authorized technician. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by calling customer support at 1-800-726-7864.
For service outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
MLAAVISH
Galaxy S24
Battery drians so quickly I have to charge three times in one day
Galaxy S24
Wow that is a lot.
NunoNina07
Galaxy S24
Me2 :-(((((
N0Y0U2114
Nebula
Galaxy S24
Remember the full screen AOD lights more pixels then the older AOD. If you want to return to the lower power AOD, you can do so by going to
Settings > Lock screen > Always On Display > then setting the style (settings navigation attached, but can't show style options since my phone doesn't have it).
Jtwizzle
Cosmic Ray
Galaxy S24
Mine seems to drain fairly quick as well. I just turned off the wallpaper on AOD to see if the helps.
GitDatPC
Galaxy S24
I tried that, but it didn't help. I just deselected the show music option, but I doubt that will do anything either.
Vjayjayy
Galaxy S24
My S24 Ultra's battery drains very quickly without even the AOD on. The SOT is like 6 hours and the phone dies. I only use common social media apps and music apps. This has gotta be an issue.
MLAAVISH
Galaxy S24
The same situation happened with me only in social media
dani514
Halo
Galaxy S24
same here about the same 6 hrs sot
