Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
Varoonta
Galaxy S24
My battery darined overnight 30%, DIsplay is set to 60 hz, all apps are in deep sleep when not used, I have just had this phone for 4 days now. I am still trying to look for a solution.
Tarrahs12
Galaxy S24
Same
mrglow
Galaxy S24
I had to return my s24 ultra. Battery is not holding power
WhyNot86
Galaxy S24
You are not alone,my base s24 went back as well.
MatthewReiter
Red Giant
Galaxy S24
Let it 7 days or so to adjust
mrglow
Galaxy S24
For $1.400 I'm not going to deal with battery issues, I will try to re order for a last time.
MatthewReiter
Red Giant
Galaxy S24
Then you'll experience it again. It needs to do all the background stuff and learn your usage patterns for about a week for an optimal battery performance. It happens after Android updates too, so after Android 15, you'll get issues and after 7 days, it'll adjust again
mrglow
Galaxy S24
With all respect, before you give any specific advice you have to ask what kind of behaviors the phone was having. My phone died completely from a 90% charge and refusing to take charge.
Sardar_Yasin
Galaxy S24
I have a major battery problem with my S24 Ultra device. It drains the battery between 22 and 24 percent, even without an internet connection and with no animation at night. I tried contacting Samsung via email, but I did not receive a satisfactory response.
If someone could help me with this problem, I would be very grateful.
userQu1JcMmaCO
Galaxy S24
On day 5 or 6 the battery gets vastly better. Just pray you don't get the green line of death screen fail.
