- Mute
01-28-2024
05:28 PM
(Last edited
02-28-2024
11:13 AM
by
SamsungJoJo
) in
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
Solved! Go to Solution.
- Mute
02-07-2024 02:11 PM in
Galaxy S24swipe down from from top of phone, click on "cog" wheel in top right hand side which is SETTINGS. From there click on magnify glass and type in "app info" to see list of your APPs.
- Mute
02-06-2024 03:58 PM in
Galaxy S24My 24U is down to less than 20% after a 16 hour day. My Iphone would still have 50% or more. I keep hearing how great the s24U's battery is but it's not very good , in my opinion. BTW, it's just as bad as my S22U, which is the reason I switched to Iphone.
- Mute
02-06-2024 04:49 PM in
Galaxy S24- Mark as New
- Mute
02-06-2024 05:09 PM (Last edited 02-06-2024 05:10 PM ) in
Galaxy S24I am getting about 10hrs of SoT.
Settings I use, Performance profile, lite, Battery, adaptive. AOD, auto!
ALL SOCIAL MEDIA APPS, deep sleeping!
Good luck, it will get better!
- Mute
02-07-2024 01:28 PM in
- Mute
02-07-2024 01:41 PM in
- Mute
- Mute
02-07-2024 02:09 PM in
- Mute
02-11-2024 03:14 AM in
Galaxy S24It is frustrating. As I was struggling between iPhone 15 and S24 Ultra. Now, after only two days, I'm sad about my choice...
- Mute
02-11-2024 12:10 PM in
Galaxy S24Even when the phone is not in use and always on display is off and no interactive wallpaper still battery is draining.
not even getting screen on time of 4h. Night there was a charge left of 34% by morning it was below 10% without phone being used .
iphone 14 is far far better than this s24 ultra now i am realsing why did i switch to S24 .
will this be sorted out in next software update ? Or what is the reason for battery draining too quick
thanks
