- Mute
03-09-2024
09:42 AM
(Last edited
03-15-2024
04:55 PM
by
SamsungAl
) in
I have a 2 year old RS27T5200SR where the ice maker is only forming partial cubes and then dumps the water in the bucket. The bucket and then fill with a solid block of ice, so I know the freezer is cold enough. Temp set for 0F (tried -5F also). Why is the tray dumping early?
Solved! Go to Solution.
![Community Manager Community Manager](/i/rank_icons/admin.gif)
- Mute
12:18 PM
(Last edited
03-20-2024
12:19 PM
by
SamsungCaleb
) in
Hello! Thank you for reaching out! I see how this can be a cause for concern with your ice maker doing this. You can try the troubleshooting in the following link to see if this will help: https://www.samsung.com/us/support/troubleshooting/TSG01001012/.
But if it does not this is something that will require service. I would recommend either calling in at 1 (800) 726-7864 or using the following link to get set up for service.
https://www.samsung.com/us/support/service/locations/
- Mute
12:18 PM
(Last edited
03-20-2024
12:19 PM
by
SamsungCaleb
) in
![](/skins/images/D3AB92087E2CF66BA561DB840AD2B6C7/responsive_peak/images/icon_anonymous_message.png)
