2024 50 inch neo oled.
(Topic created: 01-28-2025 02:45 AM)
EBE3
Cosmic Ray
LED and OLED TVs
The remote that I have doesn't work had the tv for a week. The buttons kept getting stuck. How do I get that replaced the remote? It's still under warranty and the buttons. We'll stick under and stay down and and I can't do anything with the remote?
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
I would suggest contacting customer service and requesting a replacement remote.
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
LED and OLED TVs
EBE3
Cosmic Ray
LED and OLED TVs
Yeah, I contacted them with no luck. I tried to get a replacement remote right after I got the TV and they said, I filled out the wrong ticket even though I expressed on the ticket that I need a remote replacement, not TV service and now that my warranty has ran out, they won't do anything.
GaryB82
LED and OLED TVs
I was taking it as your tv was new and still under warranty as you mentioned.  what’s the complete model number for the tv
EBE3
Cosmic Ray
LED and OLED TVs
I've done that. They tried to send a repair technician to my home when all I needed was a remote. I canceled the technician, and it was like a week later. I tried to get back in touch with Samsung. My warranty had run out, and they would not replace the remote.
3Fees
Neutron Star
LED and OLED TVs
Get a universal remote. I use a universal remote with the remote the TV came with so that I don't wear down the imprints on the buttons.
Cheers
3Fees
EBE3
Cosmic Ray
LED and OLED TVs
I have reviewed the remote's design and, frankly, I am disappointed with its substandard construction. Samsung should strive for improved quality.GalaxyAvatar_20250219_230140_1000000370_1740024100.jpg
