- Mute
12-27-2024 10:49 AM (Last edited 12-27-2024 10:51 AM ) in
QLED and The Frame TVs
Anyone have this issue with the frame tv? 65 inch 2023 model, just happend out of nowhere
Solved! Go to Solution.
- Mute
01-09-2025 11:10 AM in
QLED and The Frame TVsHello @Neek_pro! Thank you for reaching out! If this is something that's occurin on all sources then this will be something that will require service. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
- Mute
12-27-2024 05:14 PM in
QLED and The Frame TVs- Mark as New
- Mute
12-27-2024 10:58 PM in
QLED and The Frame TVsNo, nothing touched it at all
- Mute
12-28-2024 12:30 AM (Last edited 12-28-2024 12:31 AM ) in
QLED and The Frame TVsCheers
3Fees
- Mute
12-28-2024 06:04 AM in
QLED and The Frame TVsFull factory reset or a picture reset? Because I tried picture reset and didn't work
- Mute
12-29-2024 02:33 PM in
QLED and The Frame TVshere is another picture, it really stands out on white
- Mute
01-05-2025 07:07 PM in
QLED and The Frame TVsAnyone?
- Mute
01-06-2025
10:34 AM
(Last edited
01-09-2025
11:09 AM
by
SamsungCaleb
) in
This issue is a display defect where the scattering layer has broken, causing the backlight to leak outward instead of being properly diffused. The vertical line where the backlight leaks through indicates a crack in the scattering layer.
The damage may have been caused by an impact at this location, which may have been preceded by changes due to overheating. It’s worth checking if the screen is overheating in this area. As an alternative, the defect could be related to poor-quality display components. For more details, this article might be helpful: My TV screen gets very hot, tell me what to do .
- Mute
01-06-2025 12:15 PM in
QLED and The Frame TVsWeird! It's a little bit warmer in that area but nothing crazy and there's never been any impact to that area... I changed channel and it came out of nowhere honestly
- Mute
