TV does not turn on through HDMI CEC
(Topic created: 08-19-2024 08:14 PM)
wangvictorh
LED and OLED TVs
Just bought a Samsung S95D and the TV  does not reliably turn on through HDMI CEC ... I've tried using an Apple TV and a Playstation 5, both of which are set to turn the TV on through HDMI CEC and have the appropriate cables to do so (i.e. both of these devices turned my previous Samsung Q90T on without any issues prior to this TV).
This seems to be an issue  when the TV is off for more than an hour ... if the TV was just recently turned off (e.g. in the past hour), the Apple TV and the Playstation 5 are both able to turn the TV on. Anything more than an hour, the TV does not turn on successfully through these two devices
george3401
LED and OLED TVs
Cable comes on by it self
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @wangvictorh Thank you so much for posting about this! I completely understand your concerns about the TV not turning on reliably through HDMI. I'll be more than delighted to assist. If you're using multiple HDMI-CEC devices try disconnecting one and see if the issue persists. Check your HDMI-CEC settings: Go to TV's Settings menu> Navigate to the "External Device Manager" or " General settings". Ensure that "HDMI-CEC "is enabled. Also, check to see if your firmware is up to date. Go to Settings> Support> Software.
If none of the above work you can Factory reset the unit( as a last resort). Here's a link you might find helpful: https://www.samsung.com/us/support/answer/ANS00077524/
Please let us know if this helps.
wangvictorh
LED and OLED TVs
I've tried reconnecting the HDMI cables on both devices and that does not seem to help.
I've also confirmed that HDMI CEC is on ... and have even cycled it off and on to make sure that the setting is truly on.
I've also confirmed that I am on the latest firmware for my Television (e.g. Firmware 1120).
I've also tried power cycling the Television and the HDMI devices ... I've also factory reset the television and I still have the issue.
It feels like there's some "deep sleep" setting that is preventing the TV from turning on after 1+ hour of being off ... because HDMI CEC does work through my Apple TV and PS5 if the TV was only recently off (e.g. < 1 hour). Turning the TV on in this specific scenario is possible through HDMI CEC
Samsung_Moderator
LED and OLED TVs
Thank you for that information. I would like to verify a few things with you. The issues are with devices different from AppleTV and PS5 or are they causing the trouble?  Are you connecting the devices directly to the television or are you using a splitter or receiver?
user9mAdXhrn65
LED and OLED TVs
The Apple TV is directly connected to the s95d. I have a s95b that doesn’t have this issue. So I agree with the community there is an issue with in the software when the tv is turned off (sleep). Seems that the tizen is not understanding what to do with the signal form an external source. In my opinion look into the configuration of the S95b and duplicate to fix the issue.
*** not aware of s95b users having this issue
userofkdnLkmdL
Cosmic Ray
LED and OLED TVs
  • I know what the Apple engineers need to change:
Change the “On” small button on top right of Siri Remote to IR wake-up, not CEC = exactly like the Samsung Remote.
This big change will work because:
when the Samsung is off for a long time, it goes into “deep sleep” in which case, pressing the “ On” will not do anything when set to CEC wake-up.  However, when set to IR wake-up, it will wake up the TV like the Samsung Remote.
given IR, the TV setting = CEC will turn on the ATV device = BINGO.
Frank Roos
LED and OLED TVs
I have exactly the same problem.
Surreality
LED and OLED TVs
I’ve got the same problem also. I got it working reliably for a small amount of time but after swapping HDMI devices, it’s back how @wangvictorh described it.
CEC is on for both devices however the Apple TV cannot wake up the Samsung TV after about 10 minutes of the TV being turned off.
S95D with the latest generation Apple TV 4K.
The AppleTV is directly connected to the TV via HDMI1. I have a Samsung Q990D connected via eARC on HDMI3.
PlebeianPrince
LED and OLED TVs
  • I have this same issue with my s95d. I'm using a Google TV 4k. Google TV can power off the TV via CEC, but cannot power it on via CEC if the TV has been off for more than a couple of hours. I have configured the Google TV to send the power commands via IR as a workaround. My two other TVs (two different brands not Samsung) are also connected to a Google TV dongle and power on via CEC works properly.
