Help! My Frame TV remote fell in water and I cannot get it to work.
(Topic created: 08-31-2024 06:11 PM)
Quirkygirl88
QLED and The Frame TVs
Do I need to get a new remote and how do I do that?  Or can I try to fix it myself?
chris49
Cosmic Ray
Download a Unervirsal Remote on playstore, or by one. Also let it air dry a bit and stick in a jar of rice for 24 hours.
ChaosSaber
Honored Contributor
Amazon or Samsung
GaryB82
Galactic Samsung Care Ambassador
You can wait for it too dry out and hope it works. But I don't think it will and suggest ordering a new one
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
Wassim
Comet
Best suggestion is to buy a new one you can try amazon or samsung website
chris49
Cosmic Ray
