TV won't recognize/control my cable box
(Topic created: 06-13-2024 09:17 AM)
Mocha0704
Cosmic Ray
QLED and The Frame TVs
TV: Q60C
Cable Box: Xfinity XG1v4-A Model; AX014ANM
The first day I got the TV and connected the cable box to it, the TV recognized that it was Xfinity and showed it, but then it changed to HDMI 2 and when I tried unplugging and plugging it back it, it doesn't recognize it and when I do the universal remote setup and put in the model it still can't recognize it. Is anyone else experiencing this?
Robin621k
Honored Contributor
Try this, unplug everything. Power first, HDMI cables. Then wait 30 minutes, plug everything back in, power first, then HDMI cables.
Robin621k
Honored Contributor
Have you tried to perform a factory reset of your TV and start over?
Mocha0704
Cosmic Ray
Yes, it still did the same thing
Robin621k
Honored Contributor
Have you tried to put the cable box in HDMI 1, HDMI 2 is the E ARC, for a sound bar
Mocha0704
Cosmic Ray
Yes
Robin621k
Honored Contributor
bill-e
Cosmic Samsung Care Ambassador
What length is the HDMI cable?  Longer than 2m may not work.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
Mocha0704
Cosmic Ray
Mine is only 3 ft.
bill-e
It could still  be the cables so I would try another if you have one.
FYI, I did a little research recently and found a couple of articles on HDMI, specifically addressing long cable but I was surprised to find out that the most reliable length is 6'(2m)...interesting.
Bill
Robin621k
Honored Contributor
It worked for you, Yay. This is more common than you would think it would be. It has happened on every TV I have owned.
