- Mute
07-16-2020
07:23 AM
(Last edited
08-27-2020
07:41 AM
by
SamsungJam
) in
Bought a Samsung washer and dryer, had it installed on July 8 2020. I did 3 loads of laundry over a period of 3 days. On the fourth did a load of laundry and went to open the dryer door, the the inner glass just shattered. mind you I had no clothes in the dryer, just opened the door and glass went all over the place..
I am have problem with getting Costco.com to in contact with what their going to do about the situation.
Is this a common problem with the glass shattering and innerglassshould just return the Dryer and buy some other brand. thanks
Solved! Go to Solution.
![Samsung Moderator Samsung Moderator](/i/rank_icons/moderator.gif)
- Mute
07-15-2021 07:14 AM in
Washers and DryersI am sorry you have to experience this. Can I have your full model code and serial number via private message?
- Mute
05-23-2021 12:58 PM in
Washers and DryersWe purchased a Samsung DVE45R6100C/A3 last December to replace a similar model I had purchased in 2012. It was such a fantastic set, we bought the new one.
During a standard Drying cycle last month the inner glass shattered. Samsung service told us to buy a new part as it was not covered under warranty. We have to replace the entire door and it is out of stock everywhere. Home Depot will not take it back as it is outside their return window.
How is shattered glass cosmetic?! Why hasn't there been a recall?
The laundry is full of slivers of glass, I cannot use our dryer, and I was cut multiple times trying to clean it up.
- Mute
05-23-2021 05:40 PM (Last edited 05-23-2021 05:40 PM ) in
Washers and DryersOh no! That's not good to hear please send me a private message with your full model and serial number and pictures of your door?
- Mute
10-10-2021 01:10 PM in
Washers and DryersHave a Samsung Dryer that’s 17 months old. Haven’t been home for a week so no usage of the dryer. Came home to a shattered inner dryer glass door. Appears from this community that it happens a lot. If I can not get a replacement glass then I will not be buying another Samsung unit. That high cost for only getting 17 months of usage it ridiculous.
- Mute
10-11-2021 05:14 PM in
Washers and DryersI totally understand and I'm glad no one was hurt! Please send me or any of the other mods a private message with the full model and serial number of the dryer so that we can get this corrected for you 🙂
- Mute
09-11-2021
03:38 AM
(Last edited
10-06-2021
04:50 PM
by
Samsung_Stephan
<IMAGE HIDDEN>
We bought our washer and dryer set in December 2018. We love it! Last night we were drying a small load containing only a king sheet, a pair of jeans, and a shirt and heard a loud sound. The inside door shattered. My husband used our shop vac to clean up the glass. I researched a little and found this has happened to others. Can you please help us?
- Mute
09-11-2021 07:29 AM in
Washers and DryersOh my gosh! I'm glad no one was hurt! Please, let me get this resolved for you 🙂 Can you shoot me a private message so that I may gather some more information?
- Mute
09-08-2021 01:58 PM in
Washers and DryersHello,
I am reaching out because I have an issue that appears to be a know event for Samsung front loading dryer owners. the clear plastic is severely cracked. This appears to be a defect of the product as the only things that go in there are soft items to dry. Perhaps when the unit heats up it creates the cracking. It has gotten significantly worse and I would like a resolution to this. Thank you so much!
Caroline
![](/skins/images/89F84A4C1B0EC6D269BA92FB53A7B076/responsive_peak/images/icon_anonymous_message.png)
- Mute
09-08-2021 02:47 PM in
Washers and DryersI will be happy to look in to your case. Please send the full model and serial numbers to this PM Link.
- Mute
01-26-2022
08:37 AM
(Last edited
11-10-2023
04:41 PM
by
SamsungAl
) in
I have had this dryer for only 2 1/2 years. Was doing a load of the usual, and heard the WORSE sound ever! Open the door and a Huge hole in the glass....Its tempered glass what the ???? And now I'm told the part isn't available???? Do better Samsung
