Dryer Door inner glass shattered
(Topic created: 07-16-2020 07:23 AM)
user2oTX9XZy6G
Washers and Dryers
Bought a Samsung washer and dryer, had it installed on July 8 2020.  I did 3 loads of laundry over a period of 3 days. On the fourth  did a load of laundry and  went to open the dryer door,  the the inner glass just shattered. mind you I had no clothes in the dryer, just opened the door and glass went all over the place..
I am have problem with getting Costco.com to in contact with what their going to do about the situation.
Is this a common problem with  the glass shattering and innerglassinnerglassshould just return the Dryer and buy some other brand.  thanks
JUMP TO SOLUTION
userVqynCB35kK
Washers and Dryers
I was surprised to find radial cracks developing in the center of my dryer door acrylic circular "glass."
Model No. DVE45R6300W/A3
Serial No. *****
Is this a manufacturing defect gone bad?  My wife and I didn't hit it with anything, and it must have either taken quite a blow or be defective.  I don't want to blame the cleaning crew.  Any thoughts on why or how this might happen?
    -C
mohamed2
Washers and Dryers
Hello
SamsungTam
Honored Contributor
Washers and Dryers
I do apologize for the inconvenience this has caused. Can you send me a private message with your full model and serial number http://bit.ly/2tCGnGK
userFFFTVemHuI
Washers and Dryers
While drying clothes in a new Samsung front load dryer, the inside glass in the door shattered. I have been trying to deal online with customer service but it’s a never ending process and nothing gets solved.
if this has happened to anyone else, can you please advise if you door glass was replaced or not.
Darrell
SamsungLarry
Washers and Dryers
I am very sorry to hear this. Can I have you send your full model code and serial number via private message? I will do my best to help with this situation.
userZTH1ZmYe8X
Washers and Dryers
5 minutes into dryer cycle and I hear glass break
This happen to anyone else?
SamsungCaleb
Washers and Dryers
I understand how this may be a cause for concern please send me a private message with your full model and serial number so that I may look into this further.
userZTH1ZmYe8X
Washers and Dryers
I have service coming out on the 13th. This just scared the  out of me, and I'm glad I didn't get hurt. There was nothing in the dryer that would cause this to happen. I really hope my warranty covers this because I haven't even had the dryer a year!
SamsungCaleb
Washers and Dryers
I understand please keep me updated on the repair!
userTjlUZJpb0g
Washers and Dryers
My set is 2 years old and is already garbage. The dryer door glass literally exploded last night and sent shards of glass embedded into my clothing that was inside the dryer. I am extremely disappointed in the quality of these appliances as I also recently had to replace the rubber door gasket on the washer also. This time it’s the dryer and I can not find a replacement door! Now I’m forced to go out and buy a whole new dryer !!! Can’t believe these only lasted 2 years and 2 months! Angry!!!
